Introducción
Are the keys not registering when you type? Consider using this guide to replace the keyboard in your laptop.
  1. Please power off the computer and deplete the battery before attempting the following step.
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Press down on the battery latch and slide it to the left. Lift the battery out once it pops out.
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan. Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan. Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
    • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Turn the laptop top side up and fully open the display. The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Turn the laptop top side up and fully open the display.
    • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Pry the center control panel up from its left and right edges with the Spudger.
    • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
  6. Lift the center control panel from the laptop. Tilt the center control panel away from the display carefully.
    • Lift the center control panel from the laptop.
    • Tilt the center control panel away from the display carefully.
    • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
  7. Remove the five 3mm Phillips #0 screws.
    • Remove the five 3mm Phillips #0 screws.
  8. There two cables connected from the underside of the keyboard to the laptop. Slide and lift the keyboard towards the display to unhook it from the laptop. Tilt the keyboard away from the display carefully.
    • There two cables connected from the underside of the keyboard to the laptop.
    • Slide and lift the keyboard towards the display to unhook it from the laptop.
    • Tilt the keyboard away from the display carefully.
  9. Flip open the two latches that connect the wide keyboard cable and thin light cable to the laptop. Lift the keyboard off the laptop and set aside.
    • Flip open the two latches that connect the wide keyboard cable and thin light cable to the laptop.
    • Lift the keyboard off the laptop and set aside.
    • Don't be alarmed if the cables are already disconnected. Simply lifting the keyboard from the laptop may cause the cables to disconnect because the latches require very little force to open.
Conclusión
Una persona más ha completado esta guía.
Grant Dolmat
Miembro Desde 17/09/18
328 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 14
Todo El Tiempo: 73
