Saltar al contenido principal
Introducción
Are the images and graphics on certain websites not loading properly? Consider using this guide to replace the graphics card of your laptop.
  1. Please power off the computer and deplete the battery before attempting the following step.
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Press down on the battery latch and slide it to the left. Lift the battery out once it pops out.
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Loosen the two silver Phillips #1 screws.
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Use your hand to gently lift and remove the compartment door. Use your hand to gently lift and remove the compartment door.
    • Use your hand to gently lift and remove the compartment door.
  5. Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan. Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan. Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
    • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
  6. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  7. Turn the laptop top side up and fully open the display. The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Turn the laptop top side up and fully open the display.
    • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Pry the center control panel up from its left and right edges with the Spudger.
    • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
  8. Lift the center control panel from the laptop. Tilt the center control panel away from the display carefully.
    • Lift the center control panel from the laptop.
    • Tilt the center control panel away from the display carefully.
    • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
  9. Remove the five 3mm Phillips #0 screws.
    • Remove the five 3mm Phillips #0 screws.
  10. There two cables connected from the underside of the keyboard to the laptop. Slide and lift the keyboard towards the display to unhook it from the laptop. Tilt the keyboard away from the display carefully.
    • There two cables connected from the underside of the keyboard to the laptop.
    • Slide and lift the keyboard towards the display to unhook it from the laptop.
    • Tilt the keyboard away from the display carefully.
  11. Flip open the two latches that connect the wide keyboard cable and thin light cable to the laptop. Lift the keyboard off the laptop and set aside.
    • Flip open the two latches that connect the wide keyboard cable and thin light cable to the laptop.
    • Lift the keyboard off the laptop and set aside.
    • Don't be alarmed if the cables are already disconnected. Simply lifting the keyboard from the laptop may cause the cables to disconnect because the latches require very little force to open.
  12. Unscrew the two Phillips #1 screws that secure the bracket. The screws are held to the bracket by a washer and cannot be removed.
    • Unscrew the two Phillips #1 screws that secure the bracket.
    • The screws are held to the bracket by a washer and cannot be removed.
    • Use your hand to remove the bracket.
  13. Remove the two 4mm Phillips #1 screws that secure the Graphics Card.
    • Remove the two 4mm Phillips #1 screws that secure the Graphics Card.
  14. Use the spudger to pry and lift the  Graphics Card from its compartment. Use your hand to lift and pull out the Graphics Card.
    • Use the spudger to pry and lift the Graphics Card from its compartment.
    • Use your hand to lift and pull out the Graphics Card.
Conclusión
Andrew Ruvalcaba
Miembro Desde 17/09/18
142 Reputación
1 Guía escrita
Equipo
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 20
Todo El Tiempo: 189
