Saltar al contenido principal
Alienware M17x P01E Compartment Door Replacement
Qué necesitas
  1. Alienware M17x P01E Compartment Door Replacement, Battery: paso 1, imagen 1 de 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Compartment Door Replacement: paso 2, imagen 1 de 2 Alienware M17x P01E Compartment Door Replacement: paso 2, imagen 2 de 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Compartment Door Replacement, Compartment Door: paso 3, imagen 1 de 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Compartment Door Replacement: paso 4, imagen 1 de 2 Alienware M17x P01E Compartment Door Replacement: paso 4, imagen 2 de 2
    • Use your hand to gently lift and remove the compartment door.
Conclusión
Kevin Palacios
Miembro Desde 09/17/18
169 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 256
