Introducción
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Unscrew the two screws indicated
    • Unscrew the two screws indicated
  5. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Conclusión
6 personas más completaron esta guía.
Gabe
Miembro Desde 09/04/10
8,044 Reputación
3 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
280 Miembros
783 Guías creadas
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 20
Todo El Tiempo: 23,918
