Saltar al contenido principal
Alienware M15x Hard Drive Replacement
Qué necesitas
  1. Alienware M15x Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 Alienware M15x Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 Alienware M15x Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Hard Drive Replacement, Compartment Door: paso 2, imagen 1 de 2 Alienware M15x Hard Drive Replacement, Compartment Door: paso 2, imagen 2 de 2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Hard Drive Replacement: paso 3, imagen 1 de 3 Alienware M15x Hard Drive Replacement: paso 3, imagen 2 de 3 Alienware M15x Hard Drive Replacement: paso 3, imagen 3 de 3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Alienware M15x Hard Drive Replacement: paso 5, imagen 1 de 2 Alienware M15x Hard Drive Replacement: paso 5, imagen 2 de 2
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Alienware M15x Hard Drive Replacement: paso 6, imagen 1 de 2 Alienware M15x Hard Drive Replacement: paso 6, imagen 2 de 2
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Alienware M15x Hard Drive Replacement: paso 7, imagen 1 de 1
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
Conclusión
David Sann
Miembro Desde 01/22/18
111 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 832
