Saltar al contenido principal
Alienware M14xR2 Hard Drive Replacement
Qué necesitas
  1. Alienware M14xR2 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Hard Drive Replacement: paso 2, imagen 1 de 3 Alienware M14xR2 Hard Drive Replacement: paso 2, imagen 2 de 3 Alienware M14xR2 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Hard Drive Replacement: paso 4, imagen 1 de 3 Alienware M14xR2 Hard Drive Replacement: paso 4, imagen 2 de 3 Alienware M14xR2 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Hard Drive Replacement, Optical Drive: paso 5, imagen 1 de 3 Alienware M14xR2 Hard Drive Replacement, Optical Drive: paso 5, imagen 2 de 3 Alienware M14xR2 Hard Drive Replacement, Optical Drive: paso 5, imagen 3 de 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
  6. Alienware M14xR2 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Alienware M14xR2 Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
    • The screws are spring loaded and will not come loose from the hard drive assembly.
    • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
  7. Alienware M14xR2 Hard Drive Replacement: paso 7, imagen 1 de 2 Alienware M14xR2 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
    • Set aside the now disconnected hard drive.
Conclusión
5 personas más completaron esta guía.
Connor Bovee
Miembro Desde 09/30/13
569 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-4, Forte Fall 2013 Miembro de Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 11,068
