Saltar al contenido principal
Alienware M14xR2 Display Assembly Replacement
Qué necesitas
  1. Alienware M14xR2 Display Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Display Assembly Replacement: paso 2, imagen 1 de 3 Alienware M14xR2 Display Assembly Replacement: paso 2, imagen 2 de 3 Alienware M14xR2 Display Assembly Replacement: paso 2, imagen 3 de 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Display Assembly Replacement: paso 4, imagen 1 de 3 Alienware M14xR2 Display Assembly Replacement: paso 4, imagen 2 de 3 Alienware M14xR2 Display Assembly Replacement: paso 4, imagen 3 de 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Display Assembly Replacement, Removing the Mini-Card Antenna Cables: paso 5, imagen 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Note the routing of the WirelessHD card (optional) and mini-card antenna cables and remove them from the routing guides on the computer base.
  6. Alienware M14xR2 Display Assembly Replacement, Turn the Computer Over: paso 6, imagen 1 de 1
    • NOTE: The WirelessHD card is optional and may not be present in your computer.
    • Turn the computer over and open the display as far as possible.
  7. Alienware M14xR2 Display Assembly Replacement, Disconnecting the Display Cable: paso 7, imagen 1 de 1
    • Make sure the Center-Control Cover, the Keyboard and the Palm-Rest Assembly are removed.
    • Using the pull-tab, disconnect the display cable from the connector on the system board.
  8. Alienware M14xR2 Display Assembly Replacement, Disconnecting the Logo-Board Cable: paso 8, imagen 1 de 1
    • Disconnect the logo-board cable from the connector on the system board.
  9. Alienware M14xR2 Display Assembly Replacement, Peeling the Display Cable: paso 9, imagen 1 de 1
    • Gently peel the display cable and the logo-board cable from the system board.
  10. Alienware M14xR2 Display Assembly Replacement, Remove the Screws: paso 10, imagen 1 de 1
    • Remove the screws that secure the display assembly to the computer base.
  11. Alienware M14xR2 Display Assembly Replacement, Lifting the Display Assembly: paso 11, imagen 1 de 1
    • Gently slide the WirelessHD (optional) and mini-card antenna cables out through the slot on the computer base.
    • Lift the display assembly off the computer.
  12. Alienware M14xR2 Display Assembly Replacement, Placing the Display Assembly: paso 12, imagen 1 de 1
    • Slide the WirelessHD (optional) and mini-card antenna cables through the slot on the computer base.
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables lie between the display assembly and the computer base.
  13. Alienware M14xR2 Display Assembly Replacement, Connecting the Display Cable: paso 13, imagen 1 de 1
    • Connect the display cable and the logo-board cable to the connectors on the system board.
Conclusión
Terrence15
Miembro Desde 12/18/17
79,131 Reputación
441 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
42 Miembros
1,986 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,516
