Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Battery Pack.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Loosen the eight captive screws that secure the base cover to the computer base.
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Lift the base cover off the computer base.
    • Lift the base cover off the computer base.
  4. Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Tighten the eight screws that secure the base cover to the computer base.
    • Tighten the eight screws that secure the base cover to the computer base.
  6. WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • Remove the two screws that secure the battery pack to the computer base.
  7. Disconnect the battery pack cable from the connector on the system board.
    • Disconnect the battery pack cable from the connector on the system board.
  8. Using the pull-tab, lift the battery pack off the computer base.
    • Using the pull-tab, lift the battery pack off the computer base.
  9. Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
    • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  10. Route the battery pack cable in the routing guide
    • Route the battery pack cable in the routing guide
  11. Connect the battery pack cable to the connector on the system board.
    • Connect the battery pack cable to the connector on the system board.
Linea de Meta
2 personas más completaron esta guía.
darrius
Miembro Desde 26/03/18
5,129 Reputación
30 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
37 Miembros
2,022 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 95
