Saltar al contenido principal
Introducción
this guide will teach you how to replace the battery on your Alienware Area-51m. However, this guide is only for the person who have strong hands-on ability. If you think you cannot handle this work please find professional repair company. We are not responsible for any mistake or damage when you try to repair your computer.
Partes
No se especificaron partes.
  1. Alienware Area-51m battery Replacement, battery: paso 1, imagen 1 de 3 Alienware Area-51m battery Replacement, battery: paso 1, imagen 2 de 3 Alienware Area-51m battery Replacement, battery: paso 1, imagen 3 de 3
    • turn off the laptop and remove all the cable connect to your laptop.
    • Place the back of the laptop up.
    • Remove 6 M2.5X8 computer base screws on the baseplate.
  2. Alienware Area-51m battery Replacement: paso 2, imagen 1 de 3 Alienware Area-51m battery Replacement: paso 2, imagen 2 de 3 Alienware Area-51m battery Replacement: paso 2, imagen 3 de 3
    • this is how it looks like when you take off the baseplate.
    • remove the cable connect with battery and main board.
    • Remove all 6 M2.5X5 battery screws around the battery.
  3. Alienware Area-51m battery Replacement: paso 3, imagen 1 de 2 Alienware Area-51m battery Replacement: paso 3, imagen 2 de 2
    • take off the battery and use your new battery to instead.
    • this is how it looks like when you take off the battery(for some reason i take off the hard disk as well, you don't need to care about that.)
  4. Alienware Area-51m battery Replacement: paso 4, imagen 1 de 3 Alienware Area-51m battery Replacement: paso 4, imagen 2 de 3 Alienware Area-51m battery Replacement: paso 4, imagen 3 de 3
    • now you just need to put everything back.And do not forget to put the screws back also.
Conclusión
When reassembling your device, follow the instructions in reverse order.
yupeng ge
Miembro Desde 20/01/21
1 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 56
Todo El Tiempo: 409
