Saltar al contenido principal
Alienware 17 R4 Wi-Fi Card Replacement
Qué necesitas
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: paso 1, imagen 1 de 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Alienware 17 R4 Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: paso 3, imagen 1 de 1
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Alienware 17 R4 Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: paso 5, imagen 1 de 3 Alienware 17 R4 Wi-Fi Card Replacement: paso 5, imagen 2 de 3 Alienware 17 R4 Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: paso 6, imagen 1 de 2 Alienware 17 R4 Wi-Fi Card Replacement: paso 6, imagen 2 de 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
Conclusión
Una persona más ha completado esta guía.
Hector Mendez III
Miembro Desde 09/11/17
1,340 Reputación
8 Guías creadas
Equipo
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Miembros
9 Guías creadas
Un comentario
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 43
Todo El Tiempo: 5,088
