Saltar al contenido principal
Alienware 17 R4 Ram Replacement
Qué necesitas
  1. Alienware 17 R4 Ram Replacement, Base Cover: paso 1, imagen 1 de 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Ram Replacement: paso 2, imagen 1 de 2 Alienware 17 R4 Ram Replacement: paso 2, imagen 2 de 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): paso 3, imagen 1 de 3 Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): paso 3, imagen 2 de 3 Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): paso 3, imagen 3 de 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Ram Replacement: paso 4, imagen 1 de 3 Alienware 17 R4 Ram Replacement: paso 4, imagen 2 de 3 Alienware 17 R4 Ram Replacement: paso 4, imagen 3 de 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Ram Replacement: paso 5, imagen 1 de 3 Alienware 17 R4 Ram Replacement: paso 5, imagen 2 de 3 Alienware 17 R4 Ram Replacement: paso 5, imagen 3 de 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Ram Replacement: paso 6, imagen 1 de 2 Alienware 17 R4 Ram Replacement: paso 6, imagen 2 de 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Ram Replacement, RAM: paso 7, imagen 1 de 3 Alienware 17 R4 Ram Replacement, RAM: paso 7, imagen 2 de 3 Alienware 17 R4 Ram Replacement, RAM: paso 7, imagen 3 de 3
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Ram Replacement: paso 8, imagen 1 de 1
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
Conclusión
Una persona más ha completado esta guía.
Hector Mendez III
Miembro Desde 09/11/17
1,280 Reputación
8 Guías creadas
Equipo
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 2,650
