Introducción
In order to access the inner parts of the laptop both the fan shroud and plastic cover have to be removed. This guide will show you how to remove the plastic cover.
Qué necesitas
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
