Herramientas
Partes
No se especificaron partes.
Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
Disconnect the power-button cable from the power-button board.
Remove the screws that secure the power-button board to the palm-rest assembly.
Lift the power-button board off the palm-rest assembly.
Align the screw holes on the power-button board with the screw holes on the palm-rest assembly.
Replace the screws that secure the power-button board to the palm-rest assembly.
Connect the power-button board cable to the power-button board.
Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
