Saltar al contenido principal
Alienware 17 R2 Hard Drive Replacement
Qué necesitas
  1. Alienware 17 R2 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Make sure the laptop is unplugged from any power source.
    • Put the laptop facing down on a hard surface.
  2. Alienware 17 R2 Hard Drive Replacement: paso 2, imagen 1 de 3 Alienware 17 R2 Hard Drive Replacement: paso 2, imagen 2 de 3 Alienware 17 R2 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Unscrew the two 6mm screws on the bottom side of the laptop.
    • Lift up the back cover and slide towards you.
  3. Alienware 17 R2 Hard Drive Replacement: paso 3, imagen 1 de 2 Alienware 17 R2 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Locate the Hard Drive
  4. Alienware 17 R2 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove the screws that connect the SSD Bay to the laptop
  5. Alienware 17 R2 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Unscrew the three screws holding the hard drive
  6. Alienware 17 R2 Hard Drive Replacement: paso 6, imagen 1 de 2 Alienware 17 R2 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Unscrew the four screws on the long sides of the hard drive casing
  7. Alienware 17 R2 Hard Drive Replacement: paso 7, imagen 1 de 3 Alienware 17 R2 Hard Drive Replacement: paso 7, imagen 2 de 3 Alienware 17 R2 Hard Drive Replacement: paso 7, imagen 3 de 3
    • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
    • Your hard drive has now been successfully removed from your device
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 1,508
