Saltar al contenido principal
Alienware 17 R2 Battery Replacement
Qué necesitas
  1. Alienware 17 R2 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Be sure the laptop is turned off.
    • Unplug the laptop from the power adapter.
    • Place the laptop face down on a hard surface.
  2. Alienware 17 R2 Battery Replacement: paso 2, imagen 1 de 3 Alienware 17 R2 Battery Replacement: paso 2, imagen 2 de 3 Alienware 17 R2 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the two screws on the access door.
    • Pull up the access door and slide it off.
  3. Alienware 17 R2 Battery Replacement: paso 3, imagen 1 de 3 Alienware 17 R2 Battery Replacement: paso 3, imagen 2 de 3 Alienware 17 R2 Battery Replacement: paso 3, imagen 3 de 3
    • Carefully unplug the black cord with the yellow tag to disconnect the battery.
  4. Alienware 17 R2 Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the four cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
    • Be careful when disconnecting the cables. Their connectors are very fragile and if too much force is applied, they can come out of the PCB, causing permanent damage.
  5. Alienware 17 R2 Battery Replacement: paso 5, imagen 1 de 3 Alienware 17 R2 Battery Replacement: paso 5, imagen 2 de 3 Alienware 17 R2 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the two 2.5mm x 18mm screws from the top of the laptop.
    • Remove the four 2.5mm x 10mm screws from the left and right sides of the laptop.
    • Remove the two 2.5mm x 10mm screws from the top corners.
    • Remove the eight 2.5mm x 8mm screws from the middle of the laptop.
  6. Alienware 17 R2 Battery Replacement: paso 6, imagen 1 de 3 Alienware 17 R2 Battery Replacement: paso 6, imagen 2 de 3 Alienware 17 R2 Battery Replacement: paso 6, imagen 3 de 3
    • Slowly separate the palm rest from the laptop.
    • Disconnect the power cord from the laptop to the palm rest.
    • Remove the palm rest.
  7. Alienware 17 R2 Battery Replacement: paso 7, imagen 1 de 1
    • Unplug the two cables from the laptop.
  8. Alienware 17 R2 Battery Replacement: paso 8, imagen 1 de 3 Alienware 17 R2 Battery Replacement: paso 8, imagen 2 de 3 Alienware 17 R2 Battery Replacement: paso 8, imagen 3 de 3
    • Remove the six 2.5mm x 5mm screws.
    • Gently lift up and remove the battery.
Conclusión
5 personas más completaron esta guía.
3 comentarios
Many thanks for a decent write up. My only observation was that I don't know why there was a need to unplug the power to the palm rest and fully remove it? You have access to the battery once the palm rest is lifted. Good write up non the less
mark dale - Contestar
I agree with Mark. No need to unplug the cable to the palm rest.
lrshapiro -
I’m confused, my laptop is Alienware M17x R2 but the shape is different.
altaweel2004 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 26
Ultimos 30 días: 142
Todo El Tiempo: 12,125
