Saltar al contenido principal
Alienware 17 R2 Screen Replacement
Qué necesitas
  1. Alienware 17 R2  Screen Replacement, Display: paso 1, imagen 1 de 1
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: paso 2, imagen 1 de 2 Alienware 17 R2  Screen Replacement: paso 2, imagen 2 de 2
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: paso 3, imagen 1 de 2 Alienware 17 R2  Screen Replacement: paso 3, imagen 2 de 2
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: paso 4, imagen 1 de 3 Alienware 17 R2  Screen Replacement: paso 4, imagen 2 de 3 Alienware 17 R2  Screen Replacement: paso 4, imagen 3 de 3
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: paso 5, imagen 1 de 2 Alienware 17 R2  Screen Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: paso 6, imagen 1 de 1
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: paso 7, imagen 1 de 1
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: paso 8, imagen 1 de 1
    • Gently, lift the display away from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 3,010
