Saltar al contenido principal
Alienware 15 R3 Hard Drive Replacement
Qué necesitas
  1. Alienware 15 R3  Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Alienware 15 R3  Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Alienware 15 R3  Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Find Power in start menu and click Shut Down to turn off your Alienware 15 R3.
    • Wait a few seconds until all the lights around are off.
    • Unplug the power supply.
  2. Alienware 15 R3  Hard Drive Replacement: paso 2, imagen 1 de 3 Alienware 15 R3  Hard Drive Replacement: paso 2, imagen 2 de 3 Alienware 15 R3  Hard Drive Replacement: paso 2, imagen 3 de 3
    • Remove the seven M2.5x13 screws from the base cover.
    • Remove the base cover carefully.
    • Save these screws for later.
    • The screw on the top middle of base cover cannot be removed after unscrewing. But it is okay to remove the base cover.
  3. Alienware 15 R3  Hard Drive Replacement: paso 3, imagen 1 de 3 Alienware 15 R3  Hard Drive Replacement: paso 3, imagen 2 de 3 Alienware 15 R3  Hard Drive Replacement: paso 3, imagen 3 de 3
    • Remove the two M3x3 screws that are holding the bracket and one M2.5x8 screw holding the hard drive assembly .
  4. Alienware 15 R3  Hard Drive Replacement: paso 4, imagen 1 de 2 Alienware 15 R3  Hard Drive Replacement: paso 4, imagen 2 de 2
    • Put bottom plate back on your laptop and secure the bottom plate with the screws removed previously.
    • Prior to reassembly, clean the dust on fans as circled in picture if needed.
  5. Alienware 15 R3  Hard Drive Replacement: paso 5, imagen 1 de 1
    • Your Alienware 15 R3 is ready to roll.
Conclusión
By removing the HDD from the laptop, BSOD will never happen again when you boot the laptop. Please note that, the storage space than it was in the past.
Una persona más ha completado esta guía.
Yutong Yin
Miembro Desde 05/10/21
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 1,316
