Saltar al contenido principal
Alienware 15 R2 Hard Drive Replacement
Qué necesitas
  1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    • Place laptop upside down with the hinge facing you, then remove the two 9.0 mm Phillips #0 screws located in the center of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
    • Be sure to use your Anti-Static wrist strap for this process. Hard drives are susceptible to static damage!
  2. Alienware 15 R2 Hard Drive Replacement: paso 2, imagen 1 de 2 Alienware 15 R2 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Use the iFixit opening tool to disconnect the battery cable.
  3. Alienware 15 R2 Hard Drive Replacement: paso 3, imagen 1 de 2 Alienware 15 R2 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Use the T9 Torx bit to remove the screws on the hard drive cover.
  4. Alienware 15 R2 Hard Drive Replacement: paso 4, imagen 1 de 2 Alienware 15 R2 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Firmly pull on the plastic tab to remove connector from motherboard and remove the hard drive from it's slot.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 1,573
