Introducción
If your Alienware 15 R2 overheats often or runs loudly, replacing or cleaning the fans should be the first thing you do. When working with computers, always make sure to unplug your computer and ground yourself before reaching inner components so you don’t accidentally release an electrical charge into the sensitive technology. The discharge could potentially damage your computer’s internals.
Qué necesitas
Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
In the center of the RAM card, remove the 9 mm screw using the Phillips #0 screwdriver.
