Saltar al contenido principal
Alcatel Pop 4 Plus Front Camera Replacement
Qué necesitas
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: paso 1, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Front Camera Replacement: paso 2, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement: paso 2, imagen 2 de 2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Front Camera Replacement: paso 3, imagen 1 de 1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Front Camera Replacement: paso 4, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement: paso 4, imagen 2 de 2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: paso 5, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: paso 5, imagen 2 de 2
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Front Camera Replacement: paso 6, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement: paso 6, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Front Camera Replacement: paso 7, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement: paso 7, imagen 2 de 2
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Front Camera Replacement: paso 8, imagen 1 de 2 Alcatel Pop 4 Plus Front Camera Replacement: paso 8, imagen 2 de 2
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Front Camera Replacement: paso 9, imagen 1 de 1
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: paso 10, imagen 1 de 1
    • Disconnect the camera from the motherboard using the flattened of a spudger.
Conclusión
peter achanccaray
Miembro Desde 01/25/18
123 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S20-G6, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 289
