Saltar al contenido principal
Alcatel Pixi Theatre Battery Replacement
Qué necesitas
  1. Alcatel Pixi Theatre Battery Replacement, Battery: paso 1, imagen 1 de 3 Alcatel Pixi Theatre Battery Replacement, Battery: paso 1, imagen 2 de 3 Alcatel Pixi Theatre Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Take off the case by flipping the phone over and wedging your finger in the notch on the bottom edge. Pry up until you hear the clicking and the edge releases. Continue to pry the case up, moving around the perimeter of the phone.
    • It should pop off in various places around the perimeter of the phone, and then come off easily.
  2. Alcatel Pixi Theatre Battery Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the fourteen 3mm screws that connect the housing and the battery.
  3. Alcatel Pixi Theatre Battery Replacement: paso 3, imagen 1 de 2 Alcatel Pixi Theatre Battery Replacement: paso 3, imagen 2 de 2
    • Remove the metal bracket covering the battery connector flex cable. Now that it's unscrewed, it should come out easily.
  4. Alcatel Pixi Theatre Battery Replacement: paso 4, imagen 1 de 2 Alcatel Pixi Theatre Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery connector flex cable by sliding the black spudger under the wires and carefully prying up the entire terminal casing.
  5. Alcatel Pixi Theatre Battery Replacement: paso 5, imagen 1 de 3 Alcatel Pixi Theatre Battery Replacement: paso 5, imagen 2 de 3 Alcatel Pixi Theatre Battery Replacement: paso 5, imagen 3 de 3
    • Be careful not to insert the Jimmy too far into the phone when prying the housing apart; if you do, you may damage the motherboard inside.
    • Once removed from the rest of the phone, the sides of the housing are flimsier than the top and bottom. Be careful not to bend the housing when taking it off.
    • Starting at the top left corner and moving around the perimeter of the phone, insert the Jimmy between the housing and the phone and gently pry it up.
  6. Alcatel Pixi Theatre Battery Replacement: paso 6, imagen 1 de 3 Alcatel Pixi Theatre Battery Replacement: paso 6, imagen 2 de 3 Alcatel Pixi Theatre Battery Replacement: paso 6, imagen 3 de 3
    • Remove the blue battery by lifting it straight up, or by gently turning the phone over into your palm and catching the battery as it comes out.
Conclusión
Una persona más ha completado esta guía.
2Guía Comentarios
I am searching for a battery for my pixi theatre that I have. Does anyone know where i can get it to buy?
I'm sure these steps will work but all I have now is my beautiful phone with a dead battery and searching.
Leon Beckford - Contestar
suggest where to find the replacement batteries for this.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 1,151
