Introducción
_______________ Video tutorial: _______________
Qué necesitas
Resumen del Video
The Battery / Back cover is secured to the main frame by plastic clips.
Use a plastic tool to remove it.
Use a Phillips screwdriver and remove the two screws secured the battery connector shield.
With tweezers careful remove the battery connector shield.
Disconnect:
Touchscreen flex cable
Main Camera flex cable
LCD flex cable
Vibra-motor
New line.Remove 7x Phillips screws.
Use a hair dryer to warm the glass to soften the adhesive.
Use a knife or tool with a sharp edge and start the separating the glass from the frame.
Continue with a plastic tool.
