Saltar al contenido principal
Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement
Qué necesitas
Resumen del Video
  1. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: paso 1, imagen 1 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: paso 1, imagen 2 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: paso 1, imagen 3 de 3
    • The Battery / Back cover is secured to the main frame by plastic clips.
    • Use a plastic tool to remove it.
  2. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: paso 2, imagen 1 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: paso 2, imagen 2 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: paso 2, imagen 3 de 3
    • Use a Phillips screwdriver and remove the two screws secured the battery connector shield.
    • With tweezers careful remove the battery connector shield.
  3. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 2: paso 3, imagen 1 de 1
    • Disconnect the battery cable.
  4. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: paso 4, imagen 1 de 2 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: paso 4, imagen 2 de 2
    • Disconnect:
    • Touchscreen flex cable
    • Main Camera flex cable
    • LCD flex cable
    • Vibra-motor
    • New line.Remove 7x Phillips screws.
  5. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 5, imagen 1 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 5, imagen 2 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 5, imagen 3 de 3
    • Careful unstuck the Volume buttons flex cable and the Power button flex cable.
    • Use a plastic tool and remove the Logic board.
  6. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: paso 6, imagen 1 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: paso 6, imagen 2 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: paso 6, imagen 3 de 3
    • Use a hair dryer to warm the glass to soften the adhesive.
    • Use a knife or tool with a sharp edge and start the separating the glass from the frame.
    • Continue with a plastic tool.
  7. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 7, imagen 1 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 7, imagen 2 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 7, imagen 3 de 3
    • Insert wisdom here.
  8. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 8, imagen 1 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 8, imagen 2 de 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: paso 8, imagen 3 de 3
    • Clean the frame and install a new adhesive tape.
    • Install the touch screen.
Conclusión
ZFix
Miembro Desde 12/09/13
191,341 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,541 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 1,738
