Saltar al contenido principal
Alcatel OneTouch Pop Icon Battery Replacement
Qué necesitas
  1. Alcatel OneTouch Pop Icon Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Battery Replacement: paso 2, imagen 1 de 2 Alcatel OneTouch Pop Icon Battery Replacement: paso 2, imagen 2 de 2
    • Use your thumbnail to lift the battery from the phone.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 2,392
