Saltar al contenido principal
Alcatel OneTouch Evolve Battery Removal
Qué necesitas
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: paso 1, imagen 1 de 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: paso 2, imagen 1 de 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: paso 2, imagen 2 de 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: paso 2, imagen 3 de 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: paso 3, imagen 1 de 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: paso 4, imagen 1 de 2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: paso 4, imagen 2 de 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
Conclusión
12 personas más completaron esta guía.
Brendan Egan
Miembro Desde 10/28/14
2,467 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-5, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Miembros
12 Guías creadas
5 comentarios
Thanks 4 the info.
dennisp1964 - Contestar
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Contestar
Thank you very much!
Kath B - Contestar
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 9,987
