Saltar al contenido principal
Alcatel OneTouch Evolve Back Panel Removal
Qué necesitas
  1. Alcatel OneTouch Evolve Back Panel Removal, Locate the access tab: paso 1, imagen 1 de 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Back Panel Removal, Place the flat head end of the pry tool into the tab: paso 2, imagen 1 de 3 Alcatel OneTouch Evolve Back Panel Removal, Place the flat head end of the pry tool into the tab: paso 2, imagen 2 de 3 Alcatel OneTouch Evolve Back Panel Removal, Place the flat head end of the pry tool into the tab: paso 2, imagen 3 de 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
Conclusión
5 personas más completaron esta guía.
Brendan Egan
Miembro Desde 10/28/14
2,467 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-5, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Miembros
12 Guías creadas
Un comentario
need the back panel for model number TLiO15M1
julesbling - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 15,501
