Saltar al contenido principal
Alcatel OneTouch Elevate SIM Card Replacement
Qué necesitas
  1. Alcatel OneTouch Elevate SIM Card Replacement, Battery: paso 1, imagen 1 de 3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: paso 1, imagen 2 de 3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate SIM Card Replacement: paso 2, imagen 1 de 3 Alcatel OneTouch Elevate SIM Card Replacement: paso 2, imagen 2 de 3 Alcatel OneTouch Elevate SIM Card Replacement: paso 2, imagen 3 de 3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate SIM Card Replacement, SIM card: paso 3, imagen 1 de 2 Alcatel OneTouch Elevate SIM Card Replacement, SIM card: paso 3, imagen 2 de 2
    • Locate the SIM card slot at the top left of the phone.
    • If an SIM card is not present, you can skip to step 4
  4. Alcatel OneTouch Elevate SIM Card Replacement: paso 4, imagen 1 de 1
    • The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
  5. Alcatel OneTouch Elevate SIM Card Replacement: paso 5, imagen 1 de 2 Alcatel OneTouch Elevate SIM Card Replacement: paso 5, imagen 2 de 2
    • Grab the new SIM card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 23
Todo El Tiempo: 476
