Introducción
This guide will provide the necessary steps to replace the LCD screen from the Alcatel OneTouch Evolve 2.
Qué necesitas
Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
Use a plastic opening tool to pop the speaker press-fit connector free.
Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
Gently pry off the digitizer from the main circuit board using a spudger
2 personas más completaron esta guía.
Un comentario
Merci de nous donner l’équivalant de numériseur d'écran tactile pour Alcatel One Touch Evolve 2 4037T,l’origine est obsolète.
salut
