Saltar al contenido principal
Alcatel One Touch Evolve 2 Back Frame Replacement
Qué necesitas
  1. Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: paso 1, imagen 1 de 3 Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: paso 1, imagen 2 de 3 Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: paso 1, imagen 3 de 3
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Back Frame Replacement: paso 2, imagen 1 de 1
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Back Frame Replacement: paso 3, imagen 1 de 1
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Back Frame Replacement: paso 4, imagen 1 de 3 Alcatel One Touch Evolve 2 Back Frame Replacement: paso 4, imagen 2 de 3 Alcatel One Touch Evolve 2 Back Frame Replacement: paso 4, imagen 3 de 3
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Back Frame Replacement: paso 5, imagen 1 de 2 Alcatel One Touch Evolve 2 Back Frame Replacement: paso 5, imagen 2 de 2
    • Pull the rear frame off with your hands.
Conclusión
Andrew Bai
Miembro Desde 01/30/17
634 Reputación
5 Guías creadas
Equipo
IUPUI, Team 1-3, Baechle Spring 2017 Miembro de IUPUI, Team 1-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G3
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 937
