Saltar al contenido principal
Alcatel IdealXCITE Rear Speaker Replacement
Qué necesitas
  1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: paso 1, imagen 1 de 3 Alcatel IdealXCITE Rear Speaker Replacement, Battery: paso 1, imagen 2 de 3 Alcatel IdealXCITE Rear Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Rear Speaker Replacement: paso 2, imagen 1 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 2, imagen 2 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 2, imagen 3 de 3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: paso 3, imagen 1 de 2 Alcatel IdealXCITE Rear Speaker Replacement, Antenna: paso 3, imagen 2 de 2
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Rear Speaker Replacement: paso 4, imagen 1 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 4, imagen 2 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 4, imagen 3 de 3
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
  5. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: paso 5, imagen 1 de 3 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: paso 5, imagen 2 de 3 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: paso 5, imagen 3 de 3
    • Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
    • Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
  6. Alcatel IdealXCITE Rear Speaker Replacement: paso 6, imagen 1 de 2 Alcatel IdealXCITE Rear Speaker Replacement: paso 6, imagen 2 de 2
    • Remove the three remaining 4mm PH00 screws.
    • Remove the two 3mm PH00 screws.
  7. Alcatel IdealXCITE Rear Speaker Replacement: paso 7, imagen 1 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 7, imagen 2 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 7, imagen 3 de 3
    • Using a spudger and an iFixit opening pick, pry the midframe up.
  8. Alcatel IdealXCITE Rear Speaker Replacement: paso 8, imagen 1 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 8, imagen 2 de 3 Alcatel IdealXCITE Rear Speaker Replacement: paso 8, imagen 3 de 3
    • Pry gently between the rear case and speaker using an iFixit opening pick.
    • Reapply adhesive to the new speaker when reassembling the phone.
Conclusión
Franklin Froehlich
Miembro Desde 03/07/19
427 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 293
