Saltar al contenido principal
Alcatel IdealXCITE Antenna Replacement
Qué necesitas
  1. Alcatel IdealXCITE Antenna Replacement, Battery: paso 1, imagen 1 de 3 Alcatel IdealXCITE Antenna Replacement, Battery: paso 1, imagen 2 de 3 Alcatel IdealXCITE Antenna Replacement, Battery: paso 1, imagen 3 de 3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Antenna Replacement: paso 2, imagen 1 de 3 Alcatel IdealXCITE Antenna Replacement: paso 2, imagen 2 de 3 Alcatel IdealXCITE Antenna Replacement: paso 2, imagen 3 de 3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Antenna Replacement, Antenna: paso 3, imagen 1 de 2 Alcatel IdealXCITE Antenna Replacement, Antenna: paso 3, imagen 2 de 2
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Antenna Replacement: paso 4, imagen 1 de 3 Alcatel IdealXCITE Antenna Replacement: paso 4, imagen 2 de 3 Alcatel IdealXCITE Antenna Replacement: paso 4, imagen 3 de 3
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
Conclusión
Franklin Froehlich
Miembro Desde 03/07/19
427 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 589
