Saltar al contenido principal
Akko MOD 007 v2 Keyboard Switch Replacement
Qué necesitas
  1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: paso 1, imagen 1 de 2 Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: paso 1, imagen 2 de 2
    • Unplug the USB-C cable.
  2. Akko MOD 007 v2 Keyboard Switch Replacement: paso 2, imagen 1 de 2 Akko MOD 007 v2 Keyboard Switch Replacement: paso 2, imagen 2 de 2
    • Flip the keyboard over so the backside is facing up.
    • Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
    • Remove the three 8 mm screws using the T5 Torx screwdriver.
  3. Akko MOD 007 v2 Keyboard Switch Replacement: paso 3, imagen 1 de 2 Akko MOD 007 v2 Keyboard Switch Replacement: paso 3, imagen 2 de 2
    • Pull the front and back case apart.
    • If your keyboard is dirty, you’ll want to clean it before continuing. Use compressed air or a brush.
  4. Akko MOD 007 v2 Keyboard Switch Replacement: paso 4, imagen 1 de 2 Akko MOD 007 v2 Keyboard Switch Replacement: paso 4, imagen 2 de 2
    • Insert the keycap puller horizontally on the keycap and pull up.
    • Excessive force may break the tool or keycaps so don't yank the keycap up.
  5. Akko MOD 007 v2 Keyboard Switch Replacement: paso 5, imagen 1 de 2 Akko MOD 007 v2 Keyboard Switch Replacement: paso 5, imagen 2 de 2
    • Insert the switch puller vertically in the switch tabs and gently pull up.
  6. Akko MOD 007 v2 Keyboard Switch Replacement: paso 6, imagen 1 de 3 Akko MOD 007 v2 Keyboard Switch Replacement: paso 6, imagen 2 de 3 Akko MOD 007 v2 Keyboard Switch Replacement: paso 6, imagen 3 de 3
    • Orientate the new switch to align the pins to the board's sockets.
    • Push the switch down into the sockets.
    • Make sure the pins are aligned to sockets, as misalignment will cause the switch to be faulty.
Conclusión
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
Farhan
Miembro Desde 09/19/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 62
Todo El Tiempo: 1,020
