Saltar al contenido principal
Akai MPK25 Volume Knob / Pitch Bender Replacement
Qué necesitas
  1. Akai MPK25 Volume Knob / Pitch Bender Replacement, Face Plate: paso 1, imagen 1 de 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 2, imagen 1 de 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 3, imagen 1 de 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 4, imagen 1 de 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 4, imagen 2 de 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 4, imagen 3 de 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 5, imagen 1 de 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 5, imagen 2 de 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 5, imagen 3 de 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Volume Knob / Pitch Bender Replacement, Volume Knob / Pitch Bender: paso 6, imagen 1 de 1
    • Rotate the device 180 degrees, so that the motherboard is closest to you.
    • Take caution to not damage the ribbon cable connecting the face plate to the chassis.
    • Remove the ribbon cable connecting the knobs to the mother board by gently wiggling and pulling it away from the motherboard.
  7. Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 7, imagen 1 de 2 Akai MPK25 Volume Knob / Pitch Bender Replacement: paso 7, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-6, Maness Winter 2013 Miembro de Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 2,530
