Introducción
Use this guide if any of the keys are broken, chipped, or stuck.
Qué necesitas
Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
7 personas más completaron esta guía.
