Introducción
This guide is fairly straightforward. You will, however, remove three different types of screws. Keep track of the screws; be careful with the delicate parts, and may the device work ever in your favor.
Qué necesitas
Using a metal spudger, gently pry the cover off the bottom of the device.
To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
Rotate the internal structure so that the side containing the 5 white ports is facing upward.
Unscrew the four 10.25mm T8 screws holding the heat sink.
5 personas más completaron esta guía.
