Saltar al contenido principal
AirCard 770S Battery Replacement
Qué necesitas
  1. AirCard 770S Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the device with an open corner available and facing you.
  2. AirCard 770S Battery Replacement: paso 2, imagen 1 de 1
    • Using your finger, pry open any of the four corners of the back of your AirCard 770S, until you see the back case disconnect from the device.
  3. AirCard 770S Battery Replacement: paso 3, imagen 1 de 1
    • Lift open the back case and remove it from the device.
  4. AirCard 770S Battery Replacement: paso 4, imagen 1 de 1
    • With the bottom of the device (above the charging port) facing you, use your thumb nail to lift up the battery.
  5. AirCard 770S Battery Replacement: paso 5, imagen 1 de 1
    • Once the battery is lifted up, use the rest of your hand to remove the battery out from the device.
    • To put the battery back in to the device, make sure to align the "gold stripes" on the side of the battery to where they correspond in the base of the device, and align the backing to reassemble to device.
Conclusión
Una persona más ha completado esta guía.
Caitlin Little
Miembro Desde 10/08/18
437 Reputación
3 Guías creadas
Equipo
Marist, Team S1-G2, Chaterdon Fall 2018 Miembro de Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 1,084
