Saltar al contenido principal
AirCard 770S Back Case Replacement
Qué necesitas
  1. AirCard 770S Back Case Replacement, Back Case: paso 1, imagen 1 de 1
    • Hold the device with an open corner available and facing you.
  2. AirCard 770S Back Case Replacement: paso 2, imagen 1 de 1
    • Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
  3. AirCard 770S Back Case Replacement: paso 3, imagen 1 de 1
    • Lift open the back case and remove it from the device.
    • In order to put a new back case on, make sure to align the white nobs found on the back cover, so that you do not force the case on and cause any damage to the device.
Conclusión
Caitlin Little
Miembro Desde 10/08/18
437 Reputación
3 Guías creadas
Equipo
Marist, Team S1-G2, Chaterdon Fall 2018 Miembro de Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 177
