Saltar al contenido principal
Air Hog Smash Bots Radio Receiver Replacement
Qué necesitas
  1. Air Hog Smash Bots Radio Receiver Replacement, Batteries: paso 1, imagen 1 de 1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Radio Receiver Replacement: paso 2, imagen 1 de 1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Radio Receiver Replacement: paso 3, imagen 1 de 1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Radio Receiver Replacement, External Casing: paso 4, imagen 1 de 2 Air Hog Smash Bots Radio Receiver Replacement, External Casing: paso 4, imagen 2 de 2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Radio Receiver Replacement: paso 5, imagen 1 de 2 Air Hog Smash Bots Radio Receiver Replacement: paso 5, imagen 2 de 2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Radio Receiver Replacement: paso 6, imagen 1 de 1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Radio Receiver Replacement: paso 7, imagen 1 de 1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Radio Receiver Replacement: paso 8, imagen 1 de 2 Air Hog Smash Bots Radio Receiver Replacement: paso 8, imagen 2 de 2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: paso 9, imagen 1 de 2 Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: paso 9, imagen 2 de 2
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Air Hog Smash Bots Radio Receiver Replacement: paso 10, imagen 1 de 2 Air Hog Smash Bots Radio Receiver Replacement: paso 10, imagen 2 de 2
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-1, Baechle Spring 2016 Miembro de IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 283
