Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This outline will guide you to replace the radio receiver, if it happens to break will in use. A soldering iron will need to be used for this, directions on how to solder can be found here.
  1. Using the Phillips #0 screwdriver to remove the 8 mm screw.
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Lift and slide the batter cover  away from the tab holding it in place at the bottom.
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Remove the 3 AAA batteries.
    • Remove the 3 AAA batteries.
  4. Using a Phillip #0 screwdriver to remove the eight 8 mm screws. Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Remove the upper armor of the Smash Bot. Remove the upper armor of the Smash Bot.
    • Remove the upper armor of the Smash Bot.
  6. Hold the upper body and slide out the bottom half of the Smash Bot.
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Peel back the four decal stickers that hold the front and back of the bot together.
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Use the plastic opening tool to pry the  front and back of the lower body apart. Carefully remove the back of the bot from the front.
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Use the Phillips 0 screwdriver to remove two 4.75mm screws. Use the Phillips 0 screwdriver to remove two 4.75mm screws.
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Use the soldering workstation to remove the five wires.  Directions on how to solder can be found here. Use the soldering workstation to remove the five wires.  Directions on how to solder can be found here.
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-1, Baechle Spring 2016 Miembro de IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 202
