Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will describe how to replace the motherboard in the controller.
  1. Take out your controller and access to the back of the controller. Take out your controller and access to the back of the controller.
    • Take out your controller and access to the back of the controller.
  2. Remove the screw on  the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Remove the 2 AAA batteries.
    • Remove the 2 AAA batteries.
  4. Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel. Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Use the plastic opening tool to disconnect the front and back parts of the panel. Some of the internal components may be displaced when opening the controller.
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Using the  PH #0 bit, remove two 8 mm screws on the main board. De-solder the LED wires from the motherboard.
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-1, Baechle Spring 2016 Miembro de IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Miembros
7 Guías creadas
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 95
