Introducción
The plunger is a plastic cylinder covering the main spring which works in the air-releasing system to shoot the darts. You must be careful not to harm other parts of the blaster while taking out the trigger.
Qué necesitas
Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
Remove grey slider from the main body of the blaster.
Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the bottom spring to the air system.
Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely.
Using a screwdriver, remove the 5.2 mm phillips 00 screw holding the air system to the body of the blaster.
Grab the whole air system and carefully take it out of the main body of the blaster.
Now, grab the gray plunger with your hand and slide it outwards to remove it.
2 personas más completaron esta guía.
