Saltar al contenido principal
Air Blasters Tek Six Barrel Replacement
Qué necesitas
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: paso 1, imagen 1 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: paso 1, imagen 2 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: paso 1, imagen 3 de 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: paso 2, imagen 1 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: paso 2, imagen 2 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: paso 2, imagen 3 de 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: paso 3, imagen 1 de 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: paso 3, imagen 2 de 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: paso 3, imagen 3 de 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: paso 4, imagen 1 de 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: paso 4, imagen 2 de 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: paso 4, imagen 3 de 3
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: paso 5, imagen 1 de 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: paso 5, imagen 2 de 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: paso 5, imagen 3 de 3
    • Lift the barrel, pulling it out from under the black trigger catch
Conclusión
Joshua Taylor
Miembro Desde 09/22/14
118 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-1, Brown Fall 2014 Miembro de USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Miembros
5 Guías creadas
Un comentario
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 440
