Introducción
The barrel is the orange piece into which you insert the darts.
Qué necesitas
Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
Remove grey slider from the main body of the blaster.
Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
Lift the barrel, pulling it out from under the black trigger catch
Un comentario
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
