Saltar al contenido principal
Aiptek Pocket DVII 1.3M LCD Memory Ejecting Assembly Replacement
Qué necesitas
  1. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: paso 1, imagen 1 de 3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: paso 1, imagen 2 de 3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: paso 1, imagen 3 de 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 2, imagen 1 de 1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 4, imagen 1 de 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 4, imagen 2 de 2
    • Remove the sticky black dot.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 5, imagen 1 de 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 5, imagen 2 de 2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 6, imagen 1 de 1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 7, imagen 1 de 1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 8, imagen 1 de 1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 9, imagen 1 de 1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 10, imagen 1 de 1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 11, imagen 1 de 1
    • Remove the side cover.
    • Flip the device and locate the ejecting assembly.
  12. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 12, imagen 1 de 1
    • Remove the grey button.
  13. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 13, imagen 1 de 1
    • Push the metal arm the button was on all the way up.
  14. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 14, imagen 1 de 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: paso 14, imagen 2 de 2
    • Pop the main metal arm out of the other metal arm's socket.
    • Position the arm vertically like in the first picture. The arm should come off easily.
    • Replace the ejecting arm.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 6-4, Brown Winter 2015 Miembro de USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 119
