Introducción
The speaker plays back recorded sounds when you are watching video on the LCD screen of the device. Use this guide to replace the speaker.
Qué necesitas
Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
Slide the battery compartment cover down off of the camera body.
Remove the lanyard by pulling the grey lace through the black string loop.
Pull black string loop through the silver bracket.
Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
Lift off the lens protector housing.
Pull apart the two halves of the camera body.
