Saltar al contenido principal
Aiptek DZO-V58N Lens Replacement
Qué necesitas
  1. Aiptek DZO-V58N Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
  2. Aiptek DZO-V58N Lens Replacement: paso 2, imagen 1 de 1
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
  3. Aiptek DZO-V58N Lens Replacement, Lens Protector: paso 3, imagen 1 de 1
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
  4. Aiptek DZO-V58N Lens Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
  5. Aiptek DZO-V58N Lens Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
  6. Aiptek DZO-V58N Lens Replacement: paso 6, imagen 1 de 1
    • Use a plastic opening tool to pry off the silver face plate.
  7. Aiptek DZO-V58N Lens Replacement: paso 7, imagen 1 de 3 Aiptek DZO-V58N Lens Replacement: paso 7, imagen 2 de 3 Aiptek DZO-V58N Lens Replacement: paso 7, imagen 3 de 3
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  8. Aiptek DZO-V58N Lens Replacement: paso 8, imagen 1 de 1
    • Pull off the side control panel.
  9. Aiptek DZO-V58N Lens Replacement: paso 9, imagen 1 de 2 Aiptek DZO-V58N Lens Replacement: paso 9, imagen 2 de 2
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
  10. Aiptek DZO-V58N Lens Replacement: paso 10, imagen 1 de 2 Aiptek DZO-V58N Lens Replacement: paso 10, imagen 2 de 2
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
  11. Aiptek DZO-V58N Lens Replacement, Lens: paso 11, imagen 1 de 3 Aiptek DZO-V58N Lens Replacement, Lens: paso 11, imagen 2 de 3 Aiptek DZO-V58N Lens Replacement, Lens: paso 11, imagen 3 de 3
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
  12. Aiptek DZO-V58N Lens Replacement: paso 12, imagen 1 de 1
    • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
  13. Aiptek DZO-V58N Lens Replacement: paso 13, imagen 1 de 1
    • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
    • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
  14. Aiptek DZO-V58N Lens Replacement: paso 14, imagen 1 de 1
    • Lift off the lens.
Conclusión
Zachary Yun
Miembro Desde 04/03/12
7 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-5, Forte Spring 2012 Miembro de Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 538
