Saltar al contenido principal
Afterglow Wireless PS3 Controller Vibration Motor Replacement
Qué necesitas
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: paso 1, imagen 1 de 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: paso 1, imagen 2 de 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: paso 2, imagen 1 de 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: paso 2, imagen 2 de 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 3, imagen 1 de 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 4, imagen 1 de 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 4, imagen 2 de 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 4, imagen 3 de 3
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 5, imagen 1 de 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 5, imagen 2 de 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: paso 6, imagen 1 de 1
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
Conclusión
Natalie Cox
Miembro Desde 02/17/17
207 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S19-G5, Hoffman Spring 2017 Miembro de USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
Miembros de 4
20 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,205
