Saltar al contenido principal
Afterglow Wireless PS3 Controller Motherboard Replacement
Qué necesitas
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: paso 2, imagen 1 de 1
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: paso 3, imagen 1 de 2 Afterglow Wireless PS3 Controller Motherboard Replacement: paso 3, imagen 2 de 2
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: paso 4, imagen 1 de 2 Afterglow Wireless PS3 Controller Motherboard Replacement: paso 4, imagen 2 de 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: paso 5, imagen 1 de 2 Afterglow Wireless PS3 Controller Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: paso 6, imagen 1 de 2 Afterglow Wireless PS3 Controller Motherboard Replacement: paso 6, imagen 2 de 2
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
Conclusión
Natalie Cox
Miembro Desde 02/17/17
207 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S19-G5, Hoffman Spring 2017 Miembro de USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 999
