Saltar al contenido principal
Afterglow Wireless PS3 Controller Battery Replacement
Qué necesitas
  1. Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Battery Replacement: paso 3, imagen 1 de 1
    • Use the soldering tool to heat the solder connecting the battery wires to the motherboard.
    • The soldering gun will loosen the bonds of the solder allowing the wires to be detached. Use this guide for further details on how to solder.
Conclusión
Aj Coello
Miembro Desde 02/17/17
840 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S19-G5, Hoffman Spring 2017 Miembro de USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 42
Todo El Tiempo: 2,749
