Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Aerogarden Air Pump Replacement
Resumen del Video
  1. Aerogarden Air Pump Replacement, Aerogarden Air Pump: paso 1, imagen 1 de 2 Aerogarden Air Pump Replacement, Aerogarden Air Pump: paso 1, imagen 2 de 2
    • Remove the water and seed pod container and set it to the side.
  2. Aerogarden Air Pump Replacement: paso 2, imagen 1 de 2 Aerogarden Air Pump Replacement: paso 2, imagen 2 de 2
    • Peel back the footpads, which are located at the bottom of the Aerogarden.
    • Unscrew the eight screws on the bottom to remove the base.
  3. Aerogarden Air Pump Replacement: paso 3, imagen 1 de 2 Aerogarden Air Pump Replacement: paso 3, imagen 2 de 2
    • Disconnect the wires for the lights so the base can be fully opened.
  4. Aerogarden Air Pump Replacement: paso 4, imagen 1 de 2 Aerogarden Air Pump Replacement: paso 4, imagen 2 de 2
    • Remove the four screws holding the pump down on the plastic.
  5. Aerogarden Air Pump Replacement: paso 5, imagen 1 de 2 Aerogarden Air Pump Replacement: paso 5, imagen 2 de 2
    • Cut the wires as close to the pump as possible to preserve the length of the wire. The wire connections are covered with glue.
    • Strip the plastic that covers the wire about 1/8 inch down from the ends until the end of the wire is exposed.
    • On the circuit board, note which wire is positive and which wire is negative.
  6. Aerogarden Air Pump Replacement: paso 6, imagen 1 de 2 Aerogarden Air Pump Replacement: paso 6, imagen 2 de 2
    • Connect the wires to the new pump and solder them in or affix them with heat shrink tubing for wires. The solder should be covered with the heat shrink tubing, as well, since it is a potentially wet environment.
  7. Aerogarden Air Pump Replacement: paso 7, imagen 1 de 3 Aerogarden Air Pump Replacement: paso 7, imagen 2 de 3 Aerogarden Air Pump Replacement: paso 7, imagen 3 de 3
    • Assemble in reverse order.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jameslimon
Miembro Desde 03/20/24
145 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 368
